oh dear its not working
randombod
- CB Handle: randombod
i have fitted a springer to the rear spare wheel using a wheel carrier bracket and this is connected to the rig via an extension cable to the rig an intec m110 - plus . now i have another of the same rig that when i key the mic ( the other rig is outside the car with a mag mount antenna) this registers to the rig in the car, but when some one else uses a different type of rig i cant hear them or them hear me what have i done wrong have i blown the rig? i am tempted to get a new rig is it worth it
It sounds to me like your connection to the new Springer and Mount is faulty. If that "extension cable" has a dodgy connector on it it means the rig isn't reaching the aerial. You will hear your other rig, outside the car, as it is very very close and the rig would pick that up with virtually no aerial at all.
First thing to do is to check the SWR of the rig in the vehicle connected to the Springer on the wheelcarrier mount. I'd be willing to bet that the SWR is off the scale.
Fix that, and check again and (hopefully) you won't have blown the M110 in the vehicle and won't need to replace it.
Steve ("Cherokee")
Steve ("Cherokee")
randombod
cheers for that the extension cable was a thunderpole purchase so it cant be that maybe the male to male connector and how the other plug is attached. silly question but the cast iron is painted woudl i need to remove this paint to improve the connection?
I wouldn't say "can't be", as even Thunderpole might occasionally have a faulty bit of kit . . . say "shouldn't be" or "unlikely to be" ;)randombod wrote:the extension cable was a thunderpole purchase so it cant be that
Just check the SWR on the fitted rig... That'll at least tell you whether the problem is in that line somewhere, rather than maybe being a problem with the rig or something else.
Steve ("Cherokee")
- killer cam
- - - -> CB God <- - -
- CB Handle: killer cam
swr it
randombod
need to purchase a swr unit...... just discovered that one of the plugs has not been soldered so it has a loose wire so it could be that but will still check it out.... cheers for the advice guys
- killer cam
get that wired and it will probs be sorted
- killer cam
if the co-ax is doge or isnt wired proparley the swr will go straight over 10
- killer cam
thats what i throught !!!!!!!!!!!
