Help needed please
WOODY R
Hi, I have not posted for a long time, as i gave up awhile ago trying to find somewhere to mount my aerial bracket. I have now resolved this problem, i have mounted it to the ladder on the back door of my van. I have a Midland 48 multi, a Thunderpole aerial. I have SWR'ED it in and getting a reading of 1.5 the problem is the radio turns on, i hear it bleep, but then i am hearing nothing, no sound at all, i thought i might be hearing something, static noise or some sound, but nothing.
Any help and advice would be much appreciated thank you.
hmmm is the cable raped up or tangled by any chance ?
WOODY R
Hi, The cable is not tangled at all, the only thing with the cable is i have had to put it through the edge of the back door between the hinges, as i have no other way of getting the cable inside the van. I don't know whether this will make any difference. The cable is the soft rubber coated type.
Many thanks
just make sure you have not knocked the squelch button or any other ones ?
who put the pl259 plug on?
WOODY R
Hi, The plug was already on the lead when i bought it, it is a 4metre lead with plugs already fitted, purchased from Thunderpole.
I don't know whether this would make any difference, but i feed the aerial between the top two rungs of the ladder to stop it whipping out to far, as it is on the off side of the van.
Many thanks
what cb radio is it?
check that the cable is not pinched or damage from install
The Wizard
CB Handle: The Wizard 26TM990
the antenna must not touch any metal objects atteached to the vehicle !
true it could be that the cables got pinched and damaged the core inside?
sound's like a faulty mic easy option or voltage damage worst option
yes thats a point make sure the mikes in proparley otherwise the cb radio gose extremly quiet !
#-o #-o
WOODY R
Thank you everyone for your help. I think i have sorted it out now, i did have a quick release mount on the bottom of the aerial, which i have taken off, i have moved the aerial so that it is not touching the ladder and it is now working.
Thanks again for your help.
no problemo !
