Ground for sirio 3000
Haggis
Fitted a sirio3000 on the bonnet of my Discovery (alloy) only to find the swr off the hi end of the scale :(
After doing a bit of research on here, I run a thick speaker wire from the bottom of the mount to the body of the Discovery (steel).
But still the same thing happens......any ideas?
The bonnet is really the only place I can put it where it wont get damaged.
IF there is a differanc between 1 & 40 then swr the antenna
killer cam
CB Handle: killer cam
#-o
looks like needs shortening if higher on 40 than 1 try 1 midband and 40 uk to get the widest differance
Haggis
OK, I'll give that a go.
Was told that if I put a sheet of steel on the bonnet and mount the antenna to that ,it will act as a 'reflective plane'. can anyone confirm this?
yes but it would be over kill
killer cam
over kill oh my god lol jokes
dr pepper
CB Handle: The Hood.
Triple check your connections, you might have a bad earth on either end.
When you say speaker wire, is it cheap stuff, you'd be better with sumthink heavyer, a bit of 4mm2 stuff or old battery lead, or what works for me is rg58 cb coax with the inner and outer shorted each end.
A metal sheet shouldnt be needed on an ally bonnet its still conductive, unless its a firbreglass one in which case you'd need it.
I have the same aerial on mi punto and it works well, I've had nearly 20 miles without extra power.
Rig wiring tips: red to black, black to red, blue to bits.
killer cam
dr pepper wrote:Triple check your connections, you might have a bad earth on either end.
true
