i really want to use a sirio ??
sodium1@ntlworld.com
i have a 3/8" mounting bracket on the side of my van, with a thunderpole fm27 aerial screwed into it, i also have got a quick release on this so i can easily remove it for security reasons....my SWR is 1.4 on all 40 channels and i cannot get it any lower regarding whatever i do !!! i work in really remote areas and i also work alone, so having my rig makes me feel more comfortable knowing that in an area where there is no mobile phone coverage, if in an emergency i can get assistance.. i also admit to having a little burner connected, so if i need that little bit more power in the worst areas i can get that little bit further...with the burner switched on, my SWR is in the red, and with it turned off my SWR returns to 1.4...i have been advised to purchase a sirio 3000, but this uses a so239 connection which is not compatable with my 3/8" socket !!!! is there anything i can buy what will allow me to use a sirio 3000 on my existing bracket ?? i cannot really drill anymore holes in my van as its company owned, and using a mag mount is not possible due to the hydraulics on the roof of the vehicle. I have also been looking at the stinger as a possible " plan b" problem solver...can anyone help me on this one ???
yes you can get a roof mount for the sirio give colin a ring
:D :D :D :D :D
will this convert my existing 3/8" fixing to a so239 ??
no you can not do it that way as all the connections are not made you haveto replace the mount however you can also get a converter to convert the so239 back to a 3/8 thread so you can use both types of antenna
thanks...i think i will give the sirio a miss and have a stinger instead :D
no problem but the sirio is a good antenna if you go for the orbiter make sure the base is above the roof line ton get the best swr
ok, so i get the general feeling that the coil has to be above the metalwork of the vehicle to keep the SWR down...however in the thunderpole shop ( off here ) i have got one of the side mount kits on my vehicle, and it shows a piccy of one of these fitted onto a land rover / range rover with a stinger ( i think ) screwed into it...the bottom of the coil is close to the bodywork and does this affect the SWR, why does the piccy show the coil so close to the vehicle chassis ???
yup they put it there as it looked pretty one isaloowed a mistake no and the in fact i crossed wired a set wensday it does you good now and again to mess up shows you cant walk on water use a centerl/loaded antenna or top loaded like a dv27 for good results
:cry: that's not good for those people ( i am one of them ) who have drilled 2 holes into their vehicle to accept this mount...one of those holes has to be approx 13mm !! I think the piccy should be replaced with one that is using a different aerial than a base coiled type, it has mis-led me and i now have a mount what is preety much no good to me, and i need a very flexible aerial so i do not damage it with hitting trees etc :cry:
try a baseloade midland funk 130 that may do the job and look on the bightside the day can only get better :lol:
:D :D :D :D :D
i shall use a matcher to get the SWR down on my new stinger if its over 1:5 with my 100w burner on monday when its fitted :D
