bumble bees can not fly because on the weight to wing space ratio
problem with new length of co-ax...
sounds like gordon brown has an alter ego in the states would put the above in the same catogry as the one that says
That statements not a problem, except 1. Im not in the US, 2. Gordon Brown is a twit like the majority that voted for him - pleased to say Im Blue until the day I die.
The problem is none of you have come back with any rational except 'it cant work', I summarise as simply this - a question was asked, I gave an opinion based on practical knowledge - for me it worked, BUT I also backed up the pratical knowledge with the theory that was presented - 'BUT'as usual on most forums a little 'IN' gang decides what they say is always right based on the amount of spurrious posts they've laid down over the years.( according to you guys the world is still flat, but shown as round because the factory made the globes that way
We share a forum to pass on gained knowledge and praticality, if all we're going to do is de-bunk each other, you might as well close it down - or give the stock answer to everything on here 'Ask Andy'
PS: Wizard back to Hogwarts for you. =D> =D> =D>
been at radio sinfce 1970 seen and read all the theories and tried them out to notice the differance you would have to have a very good meter
same as useing a matcher on 4 watts insted of the antten being tuned properly and 1.5 to 1 gets a lot better performance than 1 to 1
