hi all, am looking to buy an aerial for the rig I purchased recently an from what I've seen the t3-27 seems to be the best bet (for one of the shorter aerials)
is this the case or is there anything others anyone would suggest. the rig is a mini midland that has been tweaked to put out 7 watts. would the extra pwr help in any way when using a smaller aerial?
best mobile aerial
hobgobblin
- CB Handle: Hobgobblin
Go for the Wilson: I've got a Wilson 5000 tuned for 10 meters and it's FANTABULOUS!!! (Also I use a tristar groundplane radial kit on the base).
HOBGOBBLIN
- Firetrap
- CB Handle: FireTrap 26CT100
I suggest a 7ft Thunderstick / Firestik for static mobile use with a tri-star radial kit, you will struggle to find anything to work better unless you strap a antron 99 or imax 2000 to your car for static use!
I have worked fellow CT members upto 85 miles on a thunderstik and 15w/20w (Video's on my Youtube) and can easily achieve 30+ miles using 4w from a good location using the mini springer.
Try it and you wont look back - for active mobile try the Thunderpole Atom, it works well or even a full size springer antenna! cheap and effective!
I have had QSOs into most of europe, south america, south africa etc etc on just a mini springer!
I find it hard to justify spending silly money on Wilson's and K40's when cheaper alternatives match performance or beat it! Your just paying for the name and a mediocre reputation.
The Sirio 4000/5000 is the only higher-end antenna i would buy and not regret - they do work well!
madfish
Was getting about 50 mile, with a 5ft stinger type antenna mounted using a gutter mount on the back corner of my 4x4, on a maycom em-27 on sunday morning.
It also depends on what terrain is between you and the people you're talking to. I could get a copy where i had parked up on a mountain carpark, but dropping back down from there i couldnt hear the breaker i was talking to "up top"
Maycom EM-27, gutter mount, 5ft orbitor - Daihatsu Fourtrak 2.8TDS
Maxon CM-10, boot mount, 5ft orbitor - Daihatsu Fourtrak 2.8TDX
