help
clockworkorange
- Official CB Nut
to start with to lower that swr you need to shorten the whip, you wont do more than about 10 miles with that loft antenna anyway
- padster
- Chatter Box
- CB Handle: night owl
[quote="stampman"]make sure you are on uk frequancys and you get a squelch noise from the set they will recieve on a piece of wire with no swr
silly question but how you know your on uk frequancys rig i got is a danita 3000
- padster
- Chatter Box
set rig to uk freqencey but got nothingpadster wrote:stampman wrote:make sure you are on uk frequancys and you get a squelch noise from the set they will recieve on a piece of wire with no swr
- killer cam
- - - -> CB God <- - -
- CB Handle: killer cam
hi padster,
looking at your post seems your in a little bother at the moment is a out side antenna not a possibility ? iv got a sliver rod that's welcome to a new home cant remember what condition its in tho !
- padster
- Chatter Box
thanks very much for the offer cam but i moved and this place is rented and its a no go thanks for offer thoughkiller cam wrote:hi padster,
- killer cam
hi mate,
no worrys
no worrys
clockworkorange
- Official CB Nut
what antenna you running?
your best bet would be either a 102"whip and a ground plane kit or a dv27 on a old metal irononing board both work VERY well
