help
padster
CB Handle: night owl
checked swr readings channel 1 1.2 channel 20 1.4 channel 40 2.1 aerial is in loft but cant speak or hear anyone :mrgreen:
clockworkorange
to start with to lower that swr you need to shorten the whip, you wont do more than about 10 miles with that loft antenna anyway :mrgreen:
make sure you are on uk frequancys and you get a squelch noise from the set they will recieve on a piece of wire with no swr
padster
[quote="stampman"]make sure you are on uk frequancys and you get a squelch noise from the set they will recieve on a piece of wire with no swr
silly question but how you know your on uk frequancys rig i got is a danita 3000
padster
padster wrote:
stampman wrote:make sure you are on uk frequancys and you get a squelch noise from the set they will recieve on a piece of wire with no swr
set rig to uk freqencey but got nothing #-o
nothing as in no sound
or nothing as in squelch noise but no voices
padster
stampman wrote:nothing as in no sound
got it working but cant get out far does cb or aerial have to be earthed
could just be position of antenna and you are in a dip
killer cam
CB Handle: killer cam
hi padster,
looking at your post seems your in a little bother at the moment is a out side antenna not a possibility ? iv got a sliver rod that's welcome to a new home cant remember what condition its in tho !
padster
killer cam wrote:hi padster,
thanks very much for the offer cam but i moved and this place is rented and its a no go thanks for offer though
killer cam
hi mate,
no worrys :D
clockworkorange
what antenna you running? :?: your best bet would be either a 102"whip and a ground plane kit or a dv27 on a old metal irononing board both work VERY well
padster
clockworkorange wrote:what antenna you running? :?: your best bet would be either a 102"whip and a ground plane kit or a dv27 on a old metal irononing board both work VERY well
dv27 mate
