NOT HAPPY !!!
- padster
- Chatter Box
- CB Handle: night owl
my ss orbitor arrived today with mag mount and guess what swr was in red on connecting so i rang thunderpole i asked the guy to ring me back as i was on mobile which he did could be down to ground plane so here i am stuck with a orbitor a dv27 swr in red and fifty pound down !!!!! iput a load of foil down to try and get swr down which it did in front room and then transfered it all to loft swr went through the roof NOT HAPPY AND I GOING TO OPEN SOME RED WINE
still waiting for thunder pole to ring back
if it swrd in the front room but not in the attic then i would think there is a fault with your cable some where just sitting the mag on tin foil aint going to work mount on a buiscit tin with 4 lrngths of 9 ft wire soldered to the tin and spread out at 90 degrees to each other try outside first then transfer to attic useing same cable
- andy@thunderpole.co.uk
- Site Admin
- Contact:
Hi Padster,
It was me who you spoke to last night, after we got cut off I did try to call back but it kept going through to answerphone.
If the Orbitor has a low SWR in your front room then it proves that the antenna is tuned in and working.
Where abouts in the loft are you putting the antenna? Is there anything near it atall? As stampman says, it could be the cable. Either that or it could be the signal reflecting off something in the loft causing the SWR to go higher. Either that or the ground plane in the loft is not sufficient. Did you try mounting the magnet on the fridge freezer like we said on the telephone?
- padster
- Chatter Box
hi andy i put it in the middle of loft and it went through roof i put it on fridge and it came down i am thinking old fetting some old fridge doors for loftandy@thunderpole.co.uk wrote:Hi Padster,
and putting it in there on it
- Site Admin
- Contact:
Yeah, definitely sounds to me like groundplane issues then.
Fridge doors should be big enough for a groundplane, however if you still have issues then connecting wires like Stampman says should give you an excellent groundplane.
fridge door a bit big easier with biscuit tin and ground planes im sure sponsers have an easy build ground plane at a reasonable price simple cross with hole for mount in center
- Site Admin
- Contact:
Unfortunately sponsors don't stock an actual ground plane kit anymore but as you say normal wire will do the trick
Has it occurred to you that if both aerials display a high SWR it more than likely where / how you have them mounted rather faulty aerialspadster wrote:my ss orbitor arrived today with mag mount and guess what swr was in red on connecting so i rang thunderpole i asked the guy to ring me back as i was on mobile which he did could be down to ground plane so here i am stuck with a orbitor a dv27 swr in red and fifty pound down !!!!! iput a load of foil down to try and get swr down which it did in front room and then transfered it all to loft swr went through the roof NOT HAPPY AND I GOING TO OPEN SOME RED WINE![]()
- padster
- Chatter Box
hi grom i was not implying the aerials are faulty i was stating that i am having issues with ground planesgrom wrote:Has it occurred to you that if both aerials display a high SWR it more than likely where / how you have them mounted rather faulty aerialspadster wrote:my ss orbitor arrived today with mag mount and guess what swr was in red on connecting so i rang thunderpole i asked the guy to ring me back as i was on mobile which he did could be down to ground plane so here i am stuck with a orbitor a dv27 swr in red and fifty pound down !!!!! iput a load of foil down to try and get swr down which it did in front room and then transfered it all to loft swr went through the roof NOT HAPPY AND I GOING TO OPEN SOME RED WINE![]()
- padster
- Chatter Box
well i got two fridge doors put them on floor and put mag mount on it swr still in red looks like cable or poles to enlarge itpadster wrote:my ss orbitor arrived today with mag mount and guess what swr was in red on connecting so i rang thunderpole i asked the guy to ring me back as i was on mobile which he did could be down to ground plane so here i am stuck with a orbitor a dv27 swr in red and fifty pound down !!!!! iput a load of foil down to try and get swr down which it did in front room and then transfered it all to loft swr went through the roof NOT HAPPY AND I GOING TO OPEN SOME RED WINE![]()
