Ford Transit
- Bionic Budgie
- CB Handle: Bionic Budgie
HELP!!!! I have fitted a CB to my Ford Transit. I drilled a hole thru the roof and mounted a 'Beehive' mount, bought a short stinger, swr is nearly 3..tried lengthening it, cutting it nothing.. bought the longer version..same. Tested the coax etc..fine. Plugged my Yaesu FT857 into it to see were the antenna was tuned..lowest I can get is 2.5. The ONLY antenna I can get to tune is one of them 'Dial a match' antennas, it tunes to 1.5 but is only 2ft long and has the range of about 100yds! Since returning to CB after a break of 20 years, I see a lot of these open coil stinger type antennas about but the two I,ve got don,t tune up. I have even tried putting a gutter mount and then a mag mount on the car and playing with that..Same. I have a clamp type mount I use for ham radio, if I clamp it the gutter of the transit, the big stinger tunes to 1.5 and is fine, put it on the bolt thru mount and the swr goes up. Where do I go from here??? Catch you on Ch 19..if you can see me..you can work me!
- padster
- CB Handle: night owl
Bionic Budgie wrote:HELP!!!! I have fitted a CB to my Ford Transit. I drilled a hole thru the roof and mounted a 'Beehive' mount, bought a short stinger, swr is nearly 3..tried lengthening it, cutting it nothing.. bought the longer version..same. Tested the coax etc..fine. Plugged my Yaesu FT857 into it to see were the antenna was tuned..lowest I can get is 2.5. The ONLY antenna I can get to tune is one of them 'Dial a match' antennas, it tunes to 1.5 but is only 2ft long and has the range of about 100yds! Since returning to CB after a break of 20 years, I see a lot of these open coil stinger type antennas about but the two I,ve got don,t tune up. I have even tried putting a gutter mount and then a mag mount on the car and playing with that..Same. I have a clamp type mount I use for ham radio, if I clamp it the gutter of the transit, the big stinger tunes to 1.5 and is fine, put it on the bolt thru mount and the swr goes up. Where do I go from here??? Catch you on Ch 19..if you can see me..you can work me!
hello mate i had many problems with swr best thing i can recommend is buy a ss orbitor and a mag mount my swr is so low now its unreal
- Bionic Budgie
Hi, is the SS Orbitor any different? I have two very high quality Sirio mag mounts and have tried both mounts with the big and little stinger/orbitor antenna. I was told they are pre tuned..fit and forget..I have found them just not to tune. I am guessing either I am unlucky or all of the hundreds of these antennas I see on Cars/Trucks/Tractors etc etc are just 'bunged' on and the swr not check? I took my van down to Coastal Communications in Clacton on Saturday and he had his meter on the coax/mount everything..it foxed him! The only antenna he suggested was the Sirio 4000 which has a matching transformer in the base but, cost aside, the damn thing is nearly 6ft tall. Put that on my Transit and it is going to get broken..too big..too rigid!
Ian
Ian
- padster
well ss orbitor is pre tuned but still needs checking i think you got ground plane problems like i had i suggest a call to colin at thunderpole see ifBionic Budgie wrote:Hi, is the SS Orbitor any different? I have two very high quality Sirio mag mounts and have tried both mounts with the big and little stinger/orbitor antenna. I was told they are pre tuned..fit and forget..I have found them just not to tune. I am guessing either I am unlucky or all of the hundreds of these antennas I see on Cars/Trucks/Tractors etc etc are just 'bunged' on and the swr not check? I took my van down to Coastal Communications in Clacton on Saturday and he had his meter on the coax/mount everything..it foxed him! The only antenna he suggested was the Sirio 4000 which has a matching transformer in the base but, cost aside, the damn thing is nearly 6ft tall. Put that on my Transit and it is going to get broken..too big..too rigid!
Ian
he can shed some light on this if you read some of my comments in home base section you will see the trouble i had but dont give up mate you
will get there it had me pulling my hair out at one point
- Bionic Budgie
Oh I ain't giving up Padster... I sort this bugger out! The earth is fine..I always thought the best mount was a bolt thru the roof mount..good earth, strong mount. Just cant make out why the Stingers are so bad at tuning up. Long..long ago I had a K40 on the roof of my mark2 ford escort and had a brill time on cb. I am now past 40 and am going thru a bit of a 'Mid Life Crisis' I have started listening to an 80s radio station on DAB and now bought myself a new CB (TTI 550, smashing little radio). I do a lotta driving around Bury St Edmunds and the A14 in Suffolk and like the idea of reliving my past and getting back into CB. Things are very different now, no base stations, no '14 for a copy' calls, but still I see loads of antennas on vehicles so there MUST be folks out there! The works van is my van all the time and so I put my 'toys' in it. I run a Yaesu quad band radio for ham radio but am finding the old ham thing getting a bit boring..too much 599 qsl via buro stuff. Thought a trip back onto 27 might be some fun. I have used my FT857 and my Atas120 on cb and this works really well but don,t want a £250 antenna and a £600 radio in my works van. How hard can getting a cb antenna to work be?? Someone suggested to me that be a panel van..it may have too much earth??? Can you have too much earth on radio?
- padster
i done the same thing myself mate i am 39 and bought new equipment last year so i know what you mean about mid life crisis lol as for too much earth cant see it as i always was lead to believe the more the better i would give colin a ring tommorrow at thunderpole are you sure you have not caught the coax on door or window that would put swr through roofBionic Budgie wrote:Oh I ain't giving up Padster... I sort this bugger out! The earth is fine..I always thought the best mount was a bolt thru the roof mount..good earth, strong mount. Just cant make out why the Stingers are so bad at tuning up. Long..long ago I had a K40 on the roof of my mark2 ford escort and had a brill time on cb. I am now past 40 and am going thru a bit of a 'Mid Life Crisis' I have started listening to an 80s radio station on DAB and now bought myself a new CB (TTI 550, smashing little radio). I do a lotta driving around Bury St Edmunds and the A14 in Suffolk and like the idea of reliving my past and getting back into CB. Things are very different now, no base stations, no '14 for a copy' calls, but still I see loads of antennas on vehicles so there MUST be folks out there! The works van is my van all the time and so I put my 'toys' in it. I run a Yaesu quad band radio for ham radio but am finding the old ham thing getting a bit boring..too much 599 qsl via buro stuff. Thought a trip back onto 27 might be some fun. I have used my FT857 and my Atas120 on cb and this works really well but don,t want a £250 antenna and a £600 radio in my works van. How hard can getting a cb antenna to work be?? Someone suggested to me that be a panel van..it may have too much earth??? Can you have too much earth on radio?
- padster
let us know how you get on on also i will in box cam he maybe able to helppadster wrote:i done the same thing myself mate i am 39 and bought new equipment last year so i know what you mean about mid life crisis lol as for too much earth cant see it as i always was lead to believe the more the better i would give colin a ring tommorrow at thunderpole are you sure you have not caught the coax on door or window that would put swr through roofBionic Budgie wrote:Oh I ain't giving up Padster... I sort this bugger out! The earth is fine..I always thought the best mount was a bolt thru the roof mount..good earth, strong mount. Just cant make out why the Stingers are so bad at tuning up. Long..long ago I had a K40 on the roof of my mark2 ford escort and had a brill time on cb. I am now past 40 and am going thru a bit of a 'Mid Life Crisis' I have started listening to an 80s radio station on DAB and now bought myself a new CB (TTI 550, smashing little radio). I do a lotta driving around Bury St Edmunds and the A14 in Suffolk and like the idea of reliving my past and getting back into CB. Things are very different now, no base stations, no '14 for a copy' calls, but still I see loads of antennas on vehicles so there MUST be folks out there! The works van is my van all the time and so I put my 'toys' in it. I run a Yaesu quad band radio for ham radio but am finding the old ham thing getting a bit boring..too much 599 qsl via buro stuff. Thought a trip back onto 27 might be some fun. I have used my FT857 and my Atas120 on cb and this works really well but don,t want a £250 antenna and a £600 radio in my works van. How hard can getting a cb antenna to work be?? Someone suggested to me that be a panel van..it may have too much earth??? Can you have too much earth on radio?![]()
- killer cam
- - - -> CB God <- - -
- CB Handle: killer cam
hi mate
first of all can u give me your swr on channel 1 and also channel 40 UK fm
many thanks
many thanks
- Bionic Budgie
Hi Killer Cam, swr is 2.5 on 1 and 40. I have a widebanded FT857 and this is a handy tool to find where the antenna is tuned.. on both stingers the lowest swr I can seem to get is 2.5.I spoke to a mate of mine today who has the big stinger/orbitor on a mag mount on the cab of his truck..he told me he had tried to lower the swr but failed. He has just accepted a talk range of a mile or so!! These so called pre tuned antennas? I rang Mike at Thunderpole today and he suggested that because my van roof has beacons and a vhf quarter wave, this is throwing the tuning out..I removed the vhf antenna and moved the antenna to the front of the van on a mag mount..the swr did fall to 1.7 but if I moved it a fraction it went back up! I,m now thinking of putting a 4ft dial a match antenna on and throwing the stingers in the shed. Are these dial a match antenna any good?killer cam wrote:hi mate
many thanks
don,t you just LOVE rf!
Ian
- Bionic Budgie
Will check it out.stampman wrote:get a omega 27 antenna will swr down to sod all and wide banded so will do both bands
clockworkorange
- Official CB Nut
[b hey Bionic Budgie
firstly i have instally hundreds of these orbitor/springer antennas and they are great for the money you pay they will out preform many antennas more expensive than them and just about indestructable to boot!
now normally they are not far off swr wise but somtimes they can be a REAL PAIN IN THE ARSE!
but i have NEVER had one that wont tune. with out having your setup infront of me its abit difficult to diagnose but what i can tell ya i fitted 3 large springers and 5 small ones in farm machinery last week and most of the large springer needed 3-5" trimed off and they were all on the offside mirror arm 3 of the small springers needed 2-3" trimmed but the 2 small ones i fitted on the combine harvesters needed 5-7" trimmed!!!! they were on magmounts so that may give you a idea of how much tunning maybe requiered.
also when checking your swr if the readings on 1 and 40 are very close as in the same try ch1 on the eu band take a reading and then 40 on the uk band this may give you a better result, once you have done that if its higher on the uk ch 40 then you need to shorten the whip and vice versa but i doubt it will need lengthning this is VERY rare. also final note springers do react to other metal close to them ie other antennas ect.
hope this helps
if not come down to dorset and ill do it for ya!
][/b]
hope this helps
- Bionic Budgie
Dorset..On My Way..... maybe notclockworkorange wrote:[b hey Bionic Budgie
firstly i have instally hundreds of these orbitor/springer antennas and they are great for the money you pay they will out preform many antennas more expensive than them and just about indestructable to boot!now normally they are not far off swr wise but somtimes they can be a REAL PAIN IN THE ARSE!
hope this helpsif not come down to dorset and ill do it for ya!
][/b]
- padster
let us all know how you get on bud i will try and reach you lolBionic Budgie wrote:HELP!!!! I have fitted a CB to my Ford Transit. I drilled a hole thru the roof and mounted a 'Beehive' mount, bought a short stinger, swr is nearly 3..tried lengthening it, cutting it nothing.. bought the longer version..same. Tested the coax etc..fine. Plugged my Yaesu FT857 into it to see were the antenna was tuned..lowest I can get is 2.5. The ONLY antenna I can get to tune is one of them 'Dial a match' antennas, it tunes to 1.5 but is only 2ft long and has the range of about 100yds! Since returning to CB after a break of 20 years, I see a lot of these open coil stinger type antennas about but the two I,ve got don,t tune up. I have even tried putting a gutter mount and then a mag mount on the car and playing with that..Same. I have a clamp type mount I use for ham radio, if I clamp it the gutter of the transit, the big stinger tunes to 1.5 and is fine, put it on the bolt thru mount and the swr goes up. Where do I go from here??? Catch you on Ch 19..if you can see me..you can work me!
jumpingmaster
- Official CB Nut
- CB Handle: jumpingmaster
have you thought of taking out the beehive mount and checking it, and try using a different hole mount base, remembering to make sure the connections on the underneath see clean metal to eath to .. .
