UHF CB?
Bionic Budgie
CB Handle: Bionic Budgie
I was talking to a guy today and he told me that Ofcom are thinking about a CB band on UHF. I,m aware of the 446 slot but I think I am correct in thinking the law says you can only use walkie talkies and a rubber duck, ie..no outside antennas. Looking at You Tube, I see Australia has a uhf cb band..is the UK going to follow? What do you know Breakers?
Bionic Budgie.
Diss 8)
26-TM-037
We used to have a UHF CB system on 934 mhz ...but Ofcom sold the frequencies to mobile phone companies ...i think the plug was pulled on 934 in 1999 or there abouts....Google 934mhz there is some information about it :)
definately no uhf cb unless you call it cellular phone
Guzzy
CB Handle: Guzzy
Bionic Budgie wrote:I was talking to a guy today and he told me that Ofcom are thinking about a CB band on UHF. I,m aware of the 446 slot but I think I am correct in thinking the law says you can only use walkie talkies and a rubber duck, ie..no outside antennas. Looking at You Tube, I see Australia has a uhf cb band..is the UK going to follow? What do you know Breakers?
Bionic Budgie.
Diss 8)
We can but dream. :mrgreen:
The best we have (legally) is:
PMR446 - 8 channels.
Digital PMR446 - 16 ( or 8 ) channels.
LPD433/434 - 69 channels (very very low power though).
All of the above are a completely legal 'UHF CB' of a sort.
However... :wink:
A lot of people are using the Chinese imported handhelds and are illegally improvising on a combination of the 8 PMR446 and the 8 Digital PMR446 channels, like this:
UHF CB Channel and Frequency
UHF CB Channel. 01 …. 446.00625 MHz
UHF CB Channel. 02 …. 446.01875 MHz
UHF CB Channel. 03 …. 446.03125 MHz
UHF CB Channel. 04 …. 446.04375 MHz
UHF CB Channel. 05 …. 446.05625 MHz
UHF CB Channel. 06 …. 446.06875 MHz
UHF CB Channel. 07 …. 446.08125 MHz
UHF CB Channel. 08 …. 446.09375 MHz <<Calling Channel>>
UHF CB Channel. 09 …. 446.10625 MHz
UHF CB Channel. 10 …. 446.11875 MHz
UHF CB Channel. 11 …. 446.13125 MHz
UHF CB Channel. 12 …. 446.14375 MHz
UHF CB Channel. 13 …. 446.15625 MHz
UHF CB Channel. 14 …. 446.16875 MHz
UHF CB Channel. 15 …. 446.18125 MHz
UHF CB Channel. 16 …. 446.19375 MHz
Any standard analogue PMR446 radio will be able to access channels 01 – 08. The last eight channels (09 – 16) can only be accessed with a UHF radio capable of user programming (like one of the imported Chinese UHF radios).
Although the channel spacing is 12.5 kHz, due to the weirdly assigned frequencies, a transceiver with 6.25 kHz tuning steps is required to actually get on the exact frequency. In addition, narrow FM deviation (2.5kHz) is required to stop you splattering over the adjacent channels.
It should be noted that although channels 09-16 are legitimate PMR446 channels, they are technically assigned for digital PMR446 use only.
What does this mean?
If you use them on an analogue radio, you are technically breaking the law. The decision to do that is yours alone.
The PMR446 frequencies are used for many and varied purposes across the UK. From kids playing in their back gardens, security guards in shops, crane operators, motorcycle riding instructors talking to students, they even get used as baby monitors. Quite often you will find ‘closed user groups’ making use of the ‘walkie talkies’ completely oblivious to other users. Often they will be shocked and surprised to find other users. Many will be disturbed or annoyed to discover that others can talk to them on ‘their channels’. To avoid interrupting these ‘closed groups’ and to avoid having to listen to them, the accepted convention is to use CTCSS 08 (88.8Hz), this way you are much more likely to only hear those interested in ‘CB’ or ‘Open Channel’ communications.
The golden rule is to be considerate to other users. If you know there are other users in a ‘closed group’ already on a channel, whether they be analogue or digital users, move to a different, clear channel.
The above is for information only, do not take with alcohol, do not exceed stated dose, do not drink and drive, wear you seat belt, etc, etc, etc... :wink:
