carnt get a low swr reading
sammyt1286
hi all, im new to cbing i have just brought a (other company) setup with a metior antenna and i carnt get a swr reading below 3. it was off the scale and was getting alot of interferance, i went back to the shop but they wasnt very helpfull just made me buy more bits a new mount, cable and so on, i now have a pre made cable and this has improved the swr but only to 3. i have no resistance, a good earth what seems to happand when i go to plug the connector in to my rig i just touch the end on without pushing it in and the swr gos down to 2.1 alot better but as soon as i screw the case on to surcure it it gos back to 3 that says to me when i earth the antenna it gos high swr, i try to tell this to the blokes at (other company) but they act like they know best and dont really listen to me as i said i am new to all of this and dont understand much bout it, im hoping some1 can help me. thanks for taking your time reading this.
p.s. if i try to ajust the antenna the needle wont move and also have brought a new swr meter so thats ok
thanks again sam
jumpingmaster
CB Handle: jumpingmaster
sorry to hear that your first outing into cb radio is giving you problems, new radio and all. the company should be more help full. not selling you more stuff and not curing the problem . if thats the case i would tell them you not happy, if they wont help.. get your money back and find a decent company..hope you get sorted ,there are a lot of people out there that are helpfull..
you need an earth to get the antenna to work correctly there are a heck of a lotof posts on here about how to swr an antenna propperly so do a little bit of reading and all will come clear and welcome to the forum
jumpingmaster
like stampman said about a good earth is right. and mount grounded. wonder what the setup is mounted on ie: is the mount fixed to steel or alloy body, or are you using the setup on some other arrangement...
In europe you will find the irish truckers using eu mode , but on AM , which you would have to put your radio to ITALIAN mode so as to be able to enable the am Transmission. other uk drivers will be on the normal UK mode on FM
once you manage to get swr sorted, you will have no more need to keep swr meter in line..
sammyt1286
thank you all for the advice. the mount is drilled through my cab and its a steel cab i think that it has a good earth but have seen a electronic ground plate which would sort that out dose any1 no if these work or if its worth getting one. yes i think that the shop should be more helpful i even took my lorry to them for them to have a look but they said that they dont let there staff outside to do that, the youngest bloke is really helpful he did come out but was honest that he didnt no what the problem was. as i said it seems to drop the swr if i just touch the end parts of the connector and cb unit togeeather without screwing the connector on. but thanks for the replys again all is very helpful
what is the waggon an where is the antenna mounted where are you based if you come north ill have a look
sammyt1286
its on a merc axor 2008 its a concrete mixer in milton keynes so i dont really get up north much but thats very kind of u to have a look, the mounting point is the front corner of the drivers side and the cb id mounted to the left of me bout a meter away was the easyest plave so i didnt have to drill into trim to mount the unit. the oringal set up when i brought the kit a friend could here me bout 7 mile away but i couldnt here him but interferance was really bad i checked the swr then which was 2.7 and thats where its all started changing bit and gettin worse its been giving a rite headache for the past week
right if the swr is higher on 40 than 1 you need to trim a bit off the antenna if its an orbiter then needs mounting further away from the body as you will be getting reflection which puts the swr up do you get interferrance when the waggon is not running if so then you have to locate where its comeing from by removeing the fusese 1 x 1 till you find out which circut it is on hope this help plus you will be board when you sort it as you will have nothing to do
sammyt1286
rite i have finally got it sorted i took the lot to a bloke in the village where i live hes well in to cb, even broadcast his own radio station, he said the throught it was the antenna i brought a new one and that cured it, im so pleased now thank you for everyones help tho im very greatful. :D :D :D :D :D :D :D :D :D
glad its sorted
