ive had lots it the past sold everything about 5 year ago when i got bored.
ive now got an itch to scratch again.
i have now bought the following.
-PO 980 Extension Speaker
08027 - SWR430 Meter + Free SWR Guide
12099 - Thunderpole Red Devil
17061 - Thunderpole 3m Patch Lead
16035WILSON - Wilson Beehive Mount
01M490 - Intek M490 Plus
a mini orbitor
and a standard orbitor
im having problems getting the swr lowered. i get the following readings
ch 1 its reading 10 in the red
ch 20 its reading 12 in the red
ch 40 its reading on set
i set the meter on ch 20 by flicking the switch to fwd turn knob till needle is on set then key off.
flicked the switch to ref to get the readings.
ive checked for a good earth and coax shorts using continuity test with a multimeter.
and cut a inch off the ant and tried shortening and lenthening using the grub screws.
all 3 antennas give in the red readings almost identical to each other. but the one im wanting to use and shortened is the mini orbitor. this is fixed to my van shown in the pic below.
any help appreciated
