After coming to the conclusion that my area of Suffolks something of a "not spot" for CB as far as mobile goes, I'm in the middle of getting the stuff together to build up a home base. I've got in the supplies to build an inverted v dipole for the loft, as it seems to be the best option for this kind of install.
So next I've been looking at power supplies, after seeing the price of new ones I decided to look for a used option, on a well known auction site I found theres a section for power supplies in the industrial section. Where I managed to find a used but working Manson EP-920, from what I've been reading its nearly identical to the Palstar PS-30. The only difference is the Palstar kicks out an extra 7A.
The best bit? the Manson cost me only £30
Now I just need to see if my old York JCB 863's still working, and I could be up and going with a home base before too long, and all for less than 50 quid! (better rig to follow!)
Bargain!
- Bionic Budgie
- CB Handle: Bionic Budgie
I wonder what part of Suffolk you are in? There is a group of us on Channel 28, I,m in Diss (just over tha' bowda'), others are around Bury St Edmunds/Honington/Barrow/Redgrave. There is another group around Ipswich, I think they lurk on channel 40. If you plan to put an inverted dipole in the loft, I think you will struggle with local contacts. The dipole, being horizontal with be approx 3 spoints down to a station on a vertical and visa versa. I started with a 1/2 wave on the back of my house but that picked up a lot of noise and range was poor. I now have an Antron 99 on a 20ft pole in the back garden (hidden thru a cherry tree to keep the wife happy) and this works a lot better. Most of us also wear socks to stop our feet getting cold
If you plug the rig straight into the loft dipole, I think your gonna be disappointed. In ye olden days when nearly every house had a CB, you could get away with naff antennas and still have contacts. Today, things are different. Stations are more spread out so you need a decent antenna at a decent height..Priority One! (and some socks to be sure 8) ) Remember..you only get out what you put in.
I listen channel 28 when at home...give us a shout.
Ian
Bionic Budgie
Ian
Bionic Budgie
I'm not allowed to stick up a big antenna, its not my house, (we have to ask permission for a satellite dish if ones not already installed).
I'm not building a Horizontal dipole, I'm building an inverted v dipole. The Vee part contains both horizontal and vertical components, so it offers a bit of both. If I have room on the rafters the wire legs are going to be 1/2 wave:
- Bionic Budgie
I know the inverted will radiate some vertical signal but, depending on how far you are expecting to transmit, I think you will struggle with any type of loft antenna. If you cannot erect a normal antenna, try stealth.. a 5/8 wave vertical, ground mounted painted green or brown will work. I know a radio ham friend who could not put any outside aerials up, not even TV so he painted his ham antenna black, put one of them whirly things off the top of a traffic cone on it and put it on his house telling the council it was a weather station!! 10 years on, its still up and he's still on air. There are ways and means my friend
Anyway, good luck with the loft antenna and if you tell us roughly where you are, I,ll listen out for you.
Ian
Bionic Budgie
Also. G0YAP if ya on those bands.
Ian
Bionic Budgie
I always thought external antennas had to go at least 1/4 wavelength above ground due to the way they work, but if I can mount the antenna below roof level, then it should be OK. My house is less than 400m from where the air-sea rescue choppers take off at Wattisham. When the weathers bad, they can take off quite low, I don't want to be the cause of damaging a heli.
- Bionic Budgie
Hi again,
I appreciate your location would make it difficult. Another low profile antenna which I have used is just a half wave dipole strung up a tree. 9ft of wire pulled up as high as you can, the remaining 9ft you can loose anyway you want. I,ve used this and have good results. A halfwave end fed (Silver-rod) will work at any height. I had mine just on a 8ft plank screwed onto my shed back in the 80s and worked stations 15/20 miles away but my location then backed onto fields. Just one thing, if your gonna do a long run down the garden, it pays to use RG213 but if not practical (and this is what I have done) use Mini 8..its a half way house, better than RG58 but thinner and easier to use than 213. Where I live now in the centre of Diss, I have houses 360 degs and all the rf noise that comes with them. I,ve got my Antron 99 on a 25ft pole thru the middle of a cherry tree half way down the garden. This has bought my receive noise levels down and my tx range up. A friend of mine lives out near Redgrave, he has an end fed dipole up a Poplar tree at approx 50ft! Although we are just a few miles apart, he can hear stations at s5 which don,t even knock my static here, you just have to make the best of what you have got. With radio..its Location..Location..Location. Ham radio wise, I use a 107ft long wire coupled via a CG3000 smart-tuner but on 11 metres local this tunes but gives me a range of about 10 miles
The Antron..the furthest I,ve worked so far is Barrow, nr Bury. My mate in Redgrave talks double that.
Still enjoy my radio though
Regards
Budgie
Regards
Budgie
