BURNERS
boyscout
On the subject of burners, are they safe to use? Been talking to a few friends of mine and they said jokingly mind you don't fry yourself. So If I fit one in my car will I be turning it into a portable microwave? :?
no yoy cantcook chicken with them keep you coffe warm if you put it on top of the burner
Robin1
I know the post is old but i have two questions:
1) Does the burner increase your electricity bill?
2) You are burning 100w and a breaker 30 miles away can hear but that does not mean that he can come back to you? if he is only burning 4w?
Eviltwin
1) If you are powering a burner up in your house, then yes, you'll add to your electricity bill.
But by how much will probably depend on how often you are using it, and what wattage your burner is. Remember lightbulbs can be arround 60w, so if you leave 2 lights on, they'll use more than the burner at 100w will use, which is only really working when you are transmitting.
2) Chances are that a breaker 30 miles away with only 4w will probably not get back to you. However, with the right atmospheric conditions, and a good homebase antenna thats correctly setup, then its not impossible he could get back to you.
Robin1
Thanks for the reply.
