NP-126C Battery Pack
radiomaker
Purchased for a Eurosonic Ultimate. This tranceiver looks to be a clone of a Maycom AH-27, perhaps with the same motherboard.
The radio is fine, but the battery pack is apparently displaying a memory effect.
When I first used the radio with the new pack I got around 2 hours before I had to re-charge, next charge it was only 1 hr & last night the thing was done after not much more than 1/2 hr.
It is the battery pack, the transceiver is fine.
What on earth is going on? The battery pack was described as being NiMh type, which I thought did not exhibit this strange behaviour.
BTW: The thing did not come with a charger. I got one from Maplin's that gives 13.2V It runs the radio fine and the battery pack shows 12.2V on a meter when freshly charged
they generaly take about 18 hours to charge and make sure the charger is about 1 amp
radiomaker
It never has been run down flat, as the radio stops working at about 9V. The display starts to disappear at 9.6 anyway.
I wondered if these packs need a deep discharge the first few times to guarantee full capacity?
Charger is only rated 1.5A @ 13.2V though. I charged it until I went to bed last night and I will leave it all day today & see if I get more endurance.
There was no information with the battery pack about charging requirements.
