Got a Cobra 19DX IV EU of ebay a while back and it came with a SWR Antenna. Only can get 2 mile range if that.
What would be the best antenna to get for a small car (Seat Ibiza) rather have a mag mount the start drilling holes in the roof!
Thanks in advance
Dom
Better antenna
UnderCover Runner
- CB Handle: UnderCover Runner
Work, Sleep, Work, Sleep, Work, Sleep, Day off, lounge around, Sleep, work, sleep.
Unfortunately, if you want decent range, you have to go for a longer antenna.
Look on the bright side, if you choose one that is less than 9ft (2.74m), you are running an antenna that is actually smaller than it 'wants' to be.
There you go. Those 5.5ft (1.6m) antennas don't look so bad now, do they!?
UnderCover Runner
Just had a proper look. Thinking of the Orbiter HD Centre load.
UnderCover Runner
Cheers guys!
joe jeep
- CB Handle: Joe-Jeep
I use a modulator now the voyager and have had some good results. What's the TZ27 like?
Joseph
Joseph
Handle:Joe-Jeep
It works just fine. I like it because the coil is relatively small and discrete and the whip kind of disappears at a distance.joe jeep wrote:I use a modulator now the voyager and have had some good results. What's the TZ27 like?
Joseph
The Modulator has a mahoosive loading coil that just screams CB RADIO!!!
Laurie
- CB Handle: Whispering Thunder
I just wondered how different the Modulator was in comparison to the TP Red Devil?
I am aware that 1 is made in Kent and the other in Birmingham but wonder if there are any differences in performance?
Discuss
Discuss
Hi...i am a new user here. i think if you want decent range, you have to go for a longer antenna.Look on the bright side, if you choose one that is less than 9ft (2.74m), you are running an antenna that is actually smaller than it 'wants' to be.
