Linear amplifier
Redrage
CB Handle: Night cruiser
Just wondering if anyone uses an amp and weather they are worth getting or not
Adriano9966
:D As a radio amatuer I can use up to 50 watts on the intermediate licence but I never use more than 10 watts total
In my opinion its far better to work on your antenna system which is the real key to sucessful radio .good coax,antenna mounted as high as possible. Sometimes the difference between using an amp or not is little more than 1 s point so not much advantage if for eg you wish to improve your local range by a few miles
Where I live! I am surounded by hundreds of appartments so potentially if you tally up the poor amaturish tv and hi fi installations (old tv feeder, broadband amplifiers,badly screened appliances, unsuitable tv aerials and wrong polarisation etc) the potential for interference increases so for me under my circumstances using an amp would not be a good idea
A good antenna will give you gain so provided you can get the maximum amount of power to the aerial an antenna with 3db gain will give you the eqivilent of double the power (6db x4 9dbx6 etc) so with 3db gain 4 watts in = 8 watts out :D
If you live in a small town and you are having a local chin wag then 300mw is more than enough so a few watts will give you excellent range with the right antenna ...just my opinion I hope its useful
needle bender
Hi redrage,yeah i go along with what adriano says...the antenna is the important part of the setup...now as for using a linear amp are you talking homebase or mobile. ....a linear amp will give you an edge on others...but they need to be used with a bit of sense...i do on occasion use a hundred watt amp..but only when mobile and trying for some dx...go for a hundred watt amp at least,the smaller ones are useless...and most important be carefull if you intend using an amp from home. should you be in a built up area there is the possibility of interference and having angry neighbours banging on yer door... :)
