Hi guys, just started to fit my new rig over the weekend and wasnt getting much of a signal (or people was too far away) and i had got the SWR set at 1.3
so i popped on here to have a look for advise on the SWR.
I read about seeing what the SWR was on CH1 and CH40 so went out to check.
On CH1 i am gettin a SWR of 1.4-1.5 and on CH40 im getting 1.1 is this rite or do i need to do some more tuning?
Im running a CB with a SS Orbitor mounted on the winchbumper of my Pajero
any advise/tips would be very greatfull
Advise on SWR
hmmmmmm gutter or mag on roof could be a problem,
I have a aluminium roof crate, it is earthed to the car as i had to use it as an earth for my extra reversing/work lights.
Would that be a problem?
Also hight could be an issue, i cant get into many carparks at the moment due to the car + lifts and roof crate making 230cm my min clearence
currently the tip of the antenna is at 267cm from the ground, if i was to mount it on the crate it would be 377cm from the ground to the tip.
I do go laning and want to go off road with the local 4x4 club. What could i do?
at about the same hight as it is at the moment on my old car i could get about 10-15mils and that was with a cheep springer (orbiter rep) from maplins.
any ideas?
any ideas?
A Tankwhip would be better for static transmittions but were you mount the antenna will shape your ground plane drasticly , a Antenna mounted on the front bumper will give most of its groundplane ( transmittion range ) towards the rear of the vehicle .
Antennas are best mounted central on a vehicle for uniform groundplane but if you dont want to drill the roof then u could mount a springer on the front and rear bumper using a purpose built 75 ohm twin splitter cable.
Co phase harness http://www.thunderpole.co.uk/patchleads.htm
