Wouxun 2 m 7 cm dual band
Donga
CB Handle: Rockape
Hi all, i have just bought a Wouxun dual band radio. It covers 2 meter and 70 cm.
I have a set of mitex runing in the 449 mhz band and i have tuned it into them. now im receiving but its not transmitting to the mitex. however the green light on the mitex is comming on when i transmit but nothing is heard. as i said i am receiving from the mitex clearly. Any ideas pls.
will the wouxan transmit on 449
You will need to have the right CTCSS or DCS tone set as well as the frequency to open the squelch.
Donga
CB Handle: Rockape
Yes mate it goes up to 520 mhz
Donga
CB Handle: Rockape
Got them speaking. if you note the Mitex frequencies they are just 3 but has a possible 15 less the scan channel.
so 1-3 end in ctcss setting 65.0 then 4-6 end in i think it was 145 something etc.
Trouble im having is when i go to channel 4 it overwrites channel 1.
Im obviously not using the software correctly as i dont know how to create channels in the memory.
Has anyone got one of these radios who can set a few examples so i can follow to get a grip of it pls.
