Hi all
Due to being new to the world if cb radio was looking for help
Choosing the right antenna for the job I want to get out as far as
Possiblebut live in a dip which may hamper me I have a13ft piece of sciffold pipe
To add to the hieght or would I be better of with something for the loft
What antenna would you recommend
Thanks gentle giant
help choosing an home base antenna
gentle giant
Hi stampmam
Thanks for the reply could you recommend an antenna have read
Good things about the thunderpole 5 but what would you.
Recommend and which would be better 1/2 wave or the 5/8 wave
I ain't got a clue mate
Thanks gentle giant
Thanks gentle giant
- wildfire
- CB Handle: wildfire.
a 1/2 wave is for local dx but typically a 5/8th wave is around 1 - 1.5 dbd over a quarter wave dipole, (ignore manufacturers boastful claims) it also has a lower angle of radiation, making it a better DX antenna, but it does require some form of matching as is does not naturally give 50 ohms, but 100 Ohms. This reduces effcience slightly & also adds to price. A reasonable 5/8th wave gets my vote over a half wave every time, if there is a choice. i would also add sugar / garden canes in to the antenna to help it against strong gale force winds.
http://www.thunderpole.co.uk/base-cb-an ... -gain.html
but it all depends on your location if your in a valley & have hills around you or if you have high buildings around you then something like a sirio starduster m-400 will do you pride the starduster only has 6 db & is also 16 ft tall but will get you over high buildings & hills as the signal bounces over hills & buildings,
