My Midland 98+
A place for pics, either of your setup, your vehicle, yourself or anything else!
boyscout
My Midland 98+ fitted into work van
sorry about the messy van and the laptop bag in shot.
looks good
:D :D :D :D :D
boyscout
thanks Stampman, have changed the antenna now for a sirio ml 145 and it works a lot better, although get a bit of crackle on recieve because of roof rack and ladders. Used to have a 3' springer with tri star radials(got the swr down)& mag mount. As I now have a roof rack and big set of ladders on the van, I was thinking of mounting the springer on the roof rack with a mirror mount and quick release to try and get the loading coil above the ladders, what do you think? :wink:
yup that would work ok mount antenna as far away from ladders as you can and you should be ok
:D :D :D :D :D
