best homebase aerial
what is the best homebase aerial out there, i want one thats fairly pricedand one thats easiest to fit,i dont really want to have to erect 20 feet scaflod poles and all that on the roof.i live on one of the highest places in cheshire and are not obstructed by any thing really,i want something thats cheap and easy to sort if there is anything out there,i have a cobra cb .thanks
If you suffer from severe weather (very high winds and severe rain storms), you might want to look at something like the Thunderpole 5 (£67.50) or the Antron A99 (£69.99) or the Sirio Gain Master (£129.99). These are all fibreglass encased antenna's and will stand up to severe weather over a good few years.
If severe weather isn't so much an issue, then a simple aluminium antenna is just as good as a fibreglass encased antenna. Most people use these.
Something like the Thunderpole 1/2 Wave high Gain (£24.99) or the Thunderpole 5/8 Wave High Gain (£26.99)
If you want the best performance, look at the Sigma Mantova Turbo (£139.99) or the Sirio Gain Master (£129.99).
In all honesty, the simple 5/8 wave for about £30 is hard to beat, and even if you have to repair/replace it once or twice over a few years, it will still be cheaper than the more expensive models.
Having said that, a lot of people are raving about the Sigma Gain master at the moment. Check out YouTube.
- killer cam
- - - -> CB God <- - -
- CB Handle: killer cam
I had an A99 for many years great antenna !
- porky.69
very easy. the sections just screw into each other, like the guys say great antennas in bad weathersstanogs68 wrote:are these aerials hard to erect only am not to good on heights haha were is the best place to mount them does it have to be say on the chimney or is the gutter any good and how tall are these aerials ,thanks for the replys
Hire an antenna installer to do the climbing/fixing for you.stanogs68 wrote:are these aerials hard to erect only am not to good on heights haha were is the best place to mount them does it have to be say on the chimney or is the gutter any good and how tall are these aerials ,thanks for the replys
if i am going to get some one to do it for me i might aswell get it on the chimney on the end of a scalfold pole with a red light on top
rather then hanging off me gutter
ps what is your thouhts on the cheapest best homebased ae
rial i could get
- porky.69
buy cheap buy TWICE ... a good antenna for not alot of money a silver rodstanogs68 wrote:if i am going to get some one to do it for me i might aswell get it on the chimney on the end of a scalfold pole with a red light on toprather then hanging off me gutter
rial i could get
- killer cam
My first antenna was a thunderpole half wave silver rod it was very well built and they were very helpful with getting it set up however I think it may be worth pushing the budget a little bit more and buying an A99 from them (my second antenna) very impressed with the antenna !
- porky.69
yes i think so tokiller cam wrote:My first antenna was a thunderpole half wave silver rod it was very well built and they were very helpful with getting it set up however I think it may be worth pushing the budget a little bit more and buying an A99 from them (my second antenna) very impressed with the antenna !
i have took in what you have all said and i think i will get a silver rod but what is the difference between a 1/2 wave and 3/4 wave antenna which do i need ?, alsohow much wind can it take without breaing only im worried that i get it up and it will end up getting snapped in the wind because im ratherhigh up and exposed i dont want to have to fix it every ten minutes
plus how do you swr it when its up or can you do it when its not on the roof ,sorry for sounding silly but ive not had a cb since 1986 ha ha , thanks for the help
ps were is the best reliable cheapest place to buy from and what will it cost me for the coax and cable ,from the roof to the bedroom ,cheers for the help
