Hi all, first post on the forum and hope you can help me wade through the minefield!
I use a Midland 98 Plus in my car and whilst it's 'not bad', it's certainly not everything I expected from a CB. Whilst I've made certain that SWR is as low as possible and ground plane is good, sound quality is always lacking. Volume is OK, but due to lack of quality I struggle to understand what others are saying half of the time It's like listening to the Carling Black Label dam busters all the time http://youtu.be/iVSBtivbUs4.
So I'm looking to change my transceiver. I've set a budget of about £130-£140 max (though I find budgets hard to stick to) but I'm struggling to work out what to buy.
I know plenty of you guys out there use Midland 98 Pluses and I'm not knocking 'em, but for me it's time to move on an hopefully up!
Thanks for all your help in advance on this one...
Andy.
Ah...forgot to mention, the only other spec I can think I might want to add in is dual watch!
Looking to upgrade
Juicy_Jaffa
Distance isn't everything (as they say), it's more clarity that I'm after, but having said that, at 4 watts and with a 1.5 meter Ariel, how far will I ever get any way with a CB. I suppose ultimately a couple of miles would be a bonus! Quality of tx and rx are what I'm after, as little fuzziness and lost conversations the better.
Realistically there are so many different rigs on the market and I don't know how to narrow things down due to my lack of experience.
If I was listing features, good auto squelch, dual channel watch, good sound quality, maybe a lock to stop me switching channels by mistake (do all mics change channels?) a knob to change channels not an up and down button, good sound quality and oh yes, good sound quality.
Hope that rambling makes sense.
Andy.
Andy.
yes makes a lot of sense the trouble with cb is that the audio quality of each cb radio varies so mutch i an experimenting putting the out put through the car radio via an audio imput allowing the base and treble to be altered plus run through bigger speakers you could use the little fm transmitters to feed the radio as well
