Intek m790 plus frequency bands ?
S109
Just looking through the manual and it says when it's set on UK, it's 40 channels uk and 40 cept what does this mean ?
And it says it comes pre set on CE (cept 40ch fm 4w) I know how to change it.
I've had it sent on UK, so what's the difference between UK, CE & EU ?
Which should I be using :oops:
Thanks.
Basically there are 80 channels you can legally use in the UK, called 40 UK and 40 CEPT. When the radio is set to UK you can switch between these two bands quickly by pressing 'AM/FM' button. (note: the radio will still be on FM).
The 40 UK channels are FM only, and when set to CEPT this is FM only too.
However if you switch it to EU you can use the CEPT channels on FM or AM (which is legal in some European countries).
Hopefully that helps!!
S109
Ahhh I see now, thank you :D
