Low volume when receiving message
Mikesharp
Hi
I have a cb fitted in my land rover discovery, I have set up the aerial and have a swr of 1.1, however when I receive a message even with the volume on full it's very quiet.. The radio is a danita 3000uk.
Also the cb will no longer perform a channel search.
I do not believe the speaker is faulty as its loud until I receive a message.
Any ideas?
26-TM-037
Try plugging in an extension speaker, just to see if the internal speaker is to blame.
yes that seems a good place to start
Mikesharp
I have tried an external speaker today and there is no change
Is the cb dead ?????
Im not shure if you have the old 80 channel Danita 3000 or the new Multy norm one with loads of banks of 40 but here is the old Danita 3000 board from me old scribble pad and ive marked the pot for tuning the recieve of this set .
Mark the line of the screw head before adjusting so that incase it makes no diference you can put the trimpot back to where it was originally .
If you have the Multy Norm set i have read a thread somewhere of people soldering the channel jumpers wrong and loosing the recieve .
DANITA 3000 MULTY
http://www.youtube.com/watch?v=xYBTcc4T_eg
Transceiver CB Mobile. 4W AM/FM,
Multi (10) European Standards plus 2 Extended Bands.
European Standards:
40CH 4W AM/FM
34CH 4W AM/FM Italy
80CH 4W FM and 12CH 1W AM Germany
40CH 4W FM and 12CH 1W AM Germany
40CH 4W FM and 1W AM
40CH 4W FM
40CH 4W FM UK
40CH 4W FM EU and 40CH 4W FM UK As supplied.
40CH 4W AM/FM Polish Frequencies -5kHz
Extended Bands
400CH 4W AM/FM Russia 25.615 - 30.105
400CH 4W AM/FM Polish Frequencies -5kHz 25.610 - 30.100
Country selection...
Press and hold EMG button at switch on.
Turn channel selector to select band as shown in display.
Press EMG button.
DONE !!!
Mikesharp
[quote="Dragonfly"]Im not shure if you have the old 80 channel Danita 3000 or the new Multy norm one with loads of banks of 40 but here is the old Danita 3000 board from me old scribble pad and ive marked the pot for tuning the recieve of this set .
Image[/quote
Thanks I have the danita 3000 uk so I will try and adjust the settings
