Fitting the CB to Discovery 1
CaptainCaveman
CB Handle: CaptainCaveman
I have just taken delivery of the Maxon CM10 CB and as i dont like playing with auto electrics! What is the best way to get it fitted.
use cigarette lighter plug or wire straight to battery
hi CaptainCaveman
stampman means one of these at the following link http://www.thunderpole.co.uk/products/f ... -plug.html also if you have a mag mount with your antenna all you will need is a patch lead & a SWR meter to check if your SWR on your antenna is below 1.5 mate
if you give Andy a ring he will be happy to help you out :wink:
