Rotel RVC240 modulation problems
Satan
I brought my Rotel up from the garage after a 11 year stay to find it surprisingly working. Now, however I've discovered there is no modulation when the mic is keyed. Everything else seems to work fine.
I've taken the cover off to inspect the mic wiring & all seems as it should with no broken solder or dampness. Any ideas folks?
would suggest trying a different mic first before going in with the hammer ,chisel and jackhammer
Satan
stampman wrote:would suggest trying a different mic first before going in with the hammer ,chisel and jackhammer
Sorry I failed to mention that I did try another mic, but same thing was happening.
would seem to be a candidate for a spell on the workbench
After a long spell in a garage dust and corrosion normally get into switches and controls, so could be clear/norm switch on the front, or the mic gain control...
Or could even be internal deviation pot.
Satan
Cheers guys.
Someone may have turned the internal mic adjuster off , Think the internal mic volume horseshoe is VR3 on the Cybernet board .
Satan
Thanks again folks but I have sourced the problem. The TWO mics were to blame. I bought another 240 off eBay and the old rig works with the new mic. I'm glad of that as its a great old machine.
