I'm currently trying to fit a cb radio to my mx5 for using in car convoys etc and really this should be nice and easy except it's not so I need some ideas.
Basically I want an antenna solution that I can fit and remove quickly with as little sign as possible that it was ever there, since the antenna will only be used intermittently, but sometimes will need to be removed in a hurry.
Now obviously a mag mount fits the bill there, except my cars paint is covered by an additional layer of rubberised paint that I'm worried a mag mount will damage. So basically no mag mounts.
With a normal car I guess you'd probably just call it a day there and give up, I'm quite fortunate though in that my car is a convertible and I have a rollbar so what I'm trying to find ideally is some sort of quick release bar mount, thing is though does such a thing exist? Otherwise is there anything else out there I can use? I do have a little bit of parcel shelf room that can be used as an alternative, but I think the rollbar will cause me issues there.
Mag Mount alternatives
- wildfire
- CB Handle: wildfire.
hi IsoMX,
nice cars mate
the only solution i can think of not to damage your paint work is the CTE stainless steel hatchback mount the mount is adjustable & would look great on your boot & the 3/8 quick release would fit your bill,
http://www.thunderpole.co.uk/hatch-boot ... t-kit.html
http://www.thunderpole.co.uk/mounting-a ... nnect.html
& here is a link to a thread on this forum how the mount would look
viewtopic.php?f=16&t=4146
nice cars mate
Hopefully you'll be seeing a few 5's with CB's in the coming months, the club I belong to has really taken off lately in terms of convoys, and going to shows etc (they'll 111 of us at Japfest2) so having a few radios in the pack is useful.
I had looked at that mount and in some ways it does fit the bill, at least in so far as it'll look a lot better and be quicker to remove then a v-bolt or mirror mount on the roll bar, what I'm worried about is it how it mounts.
Looking at the design of it I'm guessing it overlaps the edge of the boot and then is tightened down with a screw presumably on the bottom to hold it in place? I'm not so worried about it possibly scratching paint etc on the lower boot edge with the screw (if people see that I'm more worried about them seeing the dead hooker I have stashed in there at the sme time), but in theory would it not rub against the edge of the boot lid (which could cause the rubber paint to start to lift) and the top?
My plan is when I'm not using it to remove the antenna completely, including the mount when not in use, and not having any sign of it being there, reason being two fold, if I leave the whip attached with the car being so low it's just begging to get snapped off by scrotes, and if I remove the whip but leave thr mount then at shows and meets etc I'm going to be repeatedly bombarded with the question "what's that?" (for added effect imagine that said in the whiny voice of a small child).
Actually thanks your post gave me some ideas of what to look for, I've now found the perfect rollbar mount only thing is thunderpole don't stock it...
Seems a pretty useful item though to be honest so I'm just trying to decide me being a newbie and all if I'm going to get into trouble, posting a link to it or dropping thunderpole an email suggesting they stock something similar.
There is the Thunderpoll Triflex which is expensive but it has three connections for - Car radio - CB radio and phone , its designed to replace the car antenna .
http://www.thunderpole.co.uk/small-cb-a ... iflex.html
It's not so much scratches I'm worried about, it's vibration and movement causing the rubber paint to lift from the normal paint below.
However I think I have found another solution one I am happy to share because it still requires bit thunderpole do sell...
Basically I'm going to get one of these: http://www.ebay.co.uk/itm/10-SHEET-META ... 3a7ca38c62
Fit a bar mount to the handle and then clamp it to the rollbar, job done. It's got kind of an improvised charm to it I think
- wildfire
or maybe better still a mirror mount to fit nice on the rollbar http://www.thunderpole.co.uk/mirror-bar ... t-kit.html
It's too small, we're talking about a 40mm rollbar
Also it's not quick to fit or remove either (which is why I'm not using the larger v-bolt version).
However it is perfect to fit to the handling of the welding clamp when it arrives, which is why I have one on order
- wildfire
wilson 1000 works just as good as the voyager as somebody tested them both side by side & said that for RX & TX they was the same my last advice on mag mounts is bigger the better & won`t move a inch. plus the wilson 1000 will cost you £100
