Tvi
Sundown
A neighbour is getting interference from my cb. My set up is a standard rotel 230, with 20ft silver rod.
My neighbours TV set up consists of sky plus with a scart from the sky box to his tv. How the hell do I stop the interference? The usual hi pass filter I bought us no use as he's not using a TV antennae or a coax patch lead to connect the box to the TV.
I'm going to try reroute my cb coax as far away as possible from his sky cdble to see if that helps.
Any ideas?
check the swr and try ferrite rings on his lead into the sky box
Sundown
Any idea what size of ferrite rings I'd need for standard sky cable?
same as std cb cable ring Colin at our sponsors he will sort you out speak up if you do cause he's a bit deaf
Sundown
stampman wrote:same as std cb cable ring Colin at our sponsors he will sort you out speak up if you do cause he's a bit deaf
Will do! Thanks! I'm deaf myself..... Could be interesting lol!
you could end up being our new sponsors
