k 30 magmount
def49
Hi guys and gals anyone got any views on the k 30 magmount got it sitting next to the sun hatch on top of an fh 12 Volvo
do you mean a k40 antenna ?? if so they are a very good antenna
def49
No def k 30 comes complete with 36 inch stainless steel whip mag mount and coax
ITS a copy antenna
def49
Had to bend it anyway kept knocking it off the top of the lorry in Germany
use an omega 27 fitted on the volvo mount and it will swr on all channels and perform well plus you dont see the coax
stampman wrote:ITS a copy antenna
another copied antenna really :roll: thanks for the heads up stampy there's another copied antenna to keep away from :roll: as we all know antennas what are a copy will never work as good as the originals.
Breaker Breaker
CB Handle: Space Commander
The K30 is pretty much identical to the K40 model, but the K30 has no quick release mechanism but incorporates a magmount directly onto the body and is much more aerodynamic :)
Jack (Space Commander) ;)
