I am wondering if i mount an antenna onto the bracket of the spotlight on the tractor will the earth be good enough?
The bracket is steel and is bolted to the frame of the cab.
If you can help please do,
Groundplane question
cmickey123
I'll take your word for it,
cmickey123
Do i have to check with the swr meter if its a mini orbitor thats pre tuned?
any antenna needs checking as they are designed with a perfect ground plane and most vehicles are not a perfect ground plane so it is always worth checking the first time you fit an antenna
