Using a mobile antenna at home...effectively. Help please!
millsrocks
CB Handle: Suicide Jockey
Hi.
i've recently come back to CB radio after a long long time off air.
My current living arrangement doesn't really allow me to put the ideal antenna on the house where i live, so i have started with using my Sirio Mobile whip mounted on a 10ft mast using the mounting brackets and radial kit that i have attached pictures of here:
Combing these with my old rig...a Harvard H-407 (which i believe is peaked to around 20watts)...i am getting a very high SWR reading across all 40 channels.
Q1: do you think that running an earth cable from the mounting bracket down to an earthing-rod in the ground outside my house will help with this? i am reading here and there that this could help my SWR dramatically.
Q2: i also get around 3 pounds of constant noise when just receiving which i'm sure is ruining my reception of those marginal stations....could this also be down to the lack of antenna ground? OR is that probably down to the fact that since i last had a home setup WIFI has been invented? :lol:
I am getting out....at least 13 miles as-the-crow-flies via a rig-check the other night, but really don't want to have extented TX in case i damage the radio.
Friendly advice welcomed here, or pretty much 24/7 via ch19 if you think i can hear you.
Thanks in advance...
"Suicide Jockey"
Leatherhead, Surrey, UK
Radios:
President Grant II (base)
President Lincoln II (mobile)
Antennas:
Sirio Gain-Master (base)
Sirio 3000 Hi-Power (mobile)
What is the antenna exactly ? so we may e able to help you it looks like a 2meter radio antenn from the pic of the base
millsrocks
hey Stampman.
Thanks for the reply
i believe the antenna is a Sirio Hi-Power 3000.
been previously using it on a mag-mount on the car for sometime with my Uniace 200 and my Cobra.
The pics i posted of the basemount and radial kit are just from the net....not my own....just for reference
HERE is a pic of my antenna set up in situ using those parts:
all that is running from this antenna is the coax itself (10 meters of it) going straight into my Harvard rig.
Currently going into the red SWR-wise.
Hope you can help...
"Suicide Jockey"
Radios:
Antennas:
what is difference between the highest channel and the lowest channel on the swr
millsrocks
both channel 1 and 40 are pretty much identical....almost 5!!
"Suicide Jockey"
Radios:
Antennas:
if it was tuned for mobile then it may be that the whip is too short and if it is a slight difference if its higher on 40 then i would think that is your problem
millsrocks
My thinking was that when the aerial was on the car, it would have had a good earth through the chassis.
Here, on the mast on the side of my house, it has no ground to earth.
There is virtually no difference in the SWR reading on 1 and 40...maybe a Gnats eyelash.
it's just incredibly high.
Plus, there's the constant minimum 3 pounds of noise day and night.
"Suicide Jockey"
Radios:
Antennas:
Your ground side will be the wrong length putting the antenna out of tune , In not shure If the Sirio is half wave or quarter wave but you will need to match its wave length on the ground side to get it to SWR and that wont be an easy job . Personally I would buy a antenna tuner or a proper Dipole Antenna .
Cheep antenna tuner http://www.thunderpole.co.uk/amateur-sw ... m-999.html
Even cheeper but probably wont handle more than 4 wats http://www.thunderpole.co.uk/swr-meters ... tcher.html
millsrocks
hello dragonfly...
thank you also for you input on this.
my sirio 3000 is a 7/8 wave antenna.
are you saying that all i need is one of these matchers to solve my SWR issue?
it would be a damn sight less hassle than getting back up on the roof and laying loads of groundplane wire! :lol:
"Suicide Jockey"
Radios:
Antennas:
can we have a picture of the swr meter on ch 1 and 40 ?
millsrocks
Here you go Stampman...
This is the first time obviously that i've seen both readings at the same time.
Both calibrated individually of course.
i admit there is more of a difference than i originally thought.
Still huge readings right?
"Suicide Jockey"
Radios:
Antennas:
Yes an antenna tuner will fool the radio into thinking the antenna is tuned properly , this will make the radio work correctly and protect the finals from frying . The antenna still wont be as efficient as a properly tuned antenna but your radio should be safe .
A better way to check SWR is to use channel 1 mid band ( EU ) and channel 40 uk , this way it will be easier to tell if your antenna is to short or to long but I would not go chopping up a expensive Sirio to make a home base .
Looking at your mounting pole ide say its to short so your antenna will be reading to long and I would guess that you would get a slightly better reading at 1 Mid band ( EU ) .
Sometimes you can get the ground wave length using a length of wire ,
There used to be a antenna calculator on the net , Ill se if I can find it .
Here is a calculator free to download , Don't no if it will calculate 5/8 wave but you could have fun making a inverted v or dipole . http://www.hamuniverse.com/dipivcal.html
millsrocks
Thanks for the info Dragonfly.
i really appreciate you taking the time to suggest solutions to my situation :)
on having last night to sleep on it, i think for what i want to get out of my setup as a bit-of-fun is considerably less than the sum of working out lengths, cuttlng wire, clambering around on the roof, and getting frustrated with how far i can get out and how efficient everything is working.
even with the Sirio 3000 i have got up there, i am probably never going to achieve any more or less than putting up, say, a Sirio Signal keeper. At least the Signal keeper is dedicated to the job and still low-profile enuff not to pee my neighbours and landlady off.
it's also tidier and less home-brew lookin' :lol:
believe, if i could throw up a 21' Silver Rod...i would.
but i have to settle on the fact that doing so isn't an option.
i'll probably cap this thread off here, unless anyone has any other suggestions.
thanks SO MUCH for getting involved....EVERYONE!!
if any of you pass thru the Leatherhead area (M25 Jct9), then call out for me on Ch19 and say hi.
Happy Xmas....
"Suicide Jockey"
Radios:
Antennas:
to me that looks like the antenna needs shortening as it is slightly higher on ch 40
