old rig Revival?
choss
Hi folks, noob to forum, be Kind.
Just got a car recently and Decided to Revive my old CB.
Got a new antenna, a stinger mini tornado, and plugged in to my old rig.
All im getting is very weak and very garbled, and no Comeback on 19 for a rigcheck.
Im wondering if my rig is hopelessly out of date?
Midland 77-104, marked PR 27 GB (CEPT PR NL)
Sorry for whats Probably a dumb Question.
hi and welcome deleted your other post which was the same no the rig should be ok and there is a lot of skip about at the moment
choss
Hi Stampman.
Cheers. just wondered if Frequencies may have Changed since it was last Running.
The new Twig is Allegedly Pretuned, but havent been able to swar it as my old SWR meter has gone kaput. Antenna says will be 1.5/1 or Better Though. How reliable are they?
Im Bristol based, Driven around and up and down M5 for signals. all very weak and garbled. Could be the skip then.
Did pick up Someone playing music? How Common is that these days? also couple holding a Lengthy conflab on 19. They were weak and garbled, keyed Mic and asked them to move off calling Channel but no idea if they Copied, as never Achieve a rig check with another breaker.
Think that radio is CEPT only and wont transmit or recieve on the UK40 so you wont hear any UK stations just european skip.
I currantly have the 77.104UK model and it works well .Also used to have the 77.104GTL which is UK40 .Also used to have the 77.104D which i think is the portapack model and is uk40 .
