PRESIDENT GRANT II mod
marsbar
I have seen a lot about the mod to put the PRESIDENT GRANT II in to export mode.
My question is if you were to move the jumper back and rejoin the wire would it be back as it was?
If so why can you not put a switch in line so you can change from one mod to the other, :?: the reason for doing this is in export mod it will not go to lets say ch 19 27,781.5mhz
marsbar
Thank you for looking I have now found the answer on another forum.
The answer is yes
clouseau
CB Handle: Clouseau
just remember that once its converted to export mode the radio will no longer be classed as legal for UK CB use regardless of how its modified. unless of course you originally purchased it as an export radio before AM and SSB was legalised in the UK in which case it may not have been legal from day one, unless the operator is a licensed ham. (depending on where and when it was purchased of course)
