Advice pls
Southwatermark
CB Handle: Not sure yet
Going to get the following CB
http://www.thunderpole.co.uk/mobile-cbs ... b-881.html
What i would like to know will it be ok to use the following PSU instead of the power pack??
http://www.thunderpole.co.uk/power-supp ... ocket.html
Thanks in advance
Its rated at .800ma . That is just short of 1 amp and as most CB radios pull 1 amp on transmit then it is to small to use for transmit though it would allow the radio to recieve .
You should be looking to buy a 3 amp power supply for homebase use .
no definitely go for the 3 amp power supply
