Burners
Johnny Mac
Is it ok to use a burner on a mobile set up in a lorry?
Johnny Mac
Is it the draw off the power and swr issues?stampman wrote:no you can but its one hell of a thing to set up
Johnny Mac
I've been looking at some of the specs on some of the high end yank export radios and some have amplifiers built into them, like Stryker and Magnum. Would these still cause problems using them on high power in a lorry? They look like they are designed for mobile use.
Johnny Mac
Ok thanks Stampman.
Would 10w output be ok without all the power and swr problems?
Johnny Mac
Thanks, yes I will. Am I right in thinking the swr will increase as the output power increases as its reflected power that causes the swr readings to increase? So a reading of 1.5 is about the max for adding output power of around 10w?stampman wrote:yes you should get awaywith that but do DO DO make sure the swr is right
Johnny Mac
Ok thanks for your help Stampmanstampman wrote:YES YOU SHOULD GET AWAY with 1.5 on the ref
