Hi all,
I've recently acquired a cb with a large antenna on a mag mount. I drive a Topline 12 plate scania and wondered where is best to place the antenna?
The Topline for those who don't know, is 13'10" high... So on the roof, the antenna smacks everything I pass under!
Scania Topline - where to fit antenna
Diesel-truckin
Thanks,
Adam
Adam
Diesel-truckin
Thanks for that, any particular gutter mount? I assume the thunderpole standard gutter mount would suffice?
Thanks,
Adam
Adam
Diesel-truckin
Great stuff. I'll be making the call tomorrow afternoon no doubt, thanks for your advice.
Thanks,
Adam
Adam
no problem have fitted quite a few r series and you may have to run 12 volts up to the top as well as scani are cutting back at one time the used to put 12 volts up there but theses days its a bit of a lottery
Diesel-truckin
Might be moving companies after this weekend! Hoping to land a scania again as I've settled into them now!stampman wrote:no problem have fitted quite a few r series and you may have to run 12 volts up to the top as well as scani are cutting back at one time the used to put 12 volts up there but theses days its a bit of a lottery
If not, I want a Volvo with the I shift...lovely motors.
Thanks,
Adam
Adam
