Hi all, just wondering if I've set my radio up correctly because I can't pick up much of a signal.
I bought a T 800 kit from Thunderpole with a body mount and an orbiter aerial.
I mounted the base on the roof making sure I scraped all the paint away for the lock nut to earth properly.
I drive a van so I had to use a 7meter cable to reach the radio.
The radio is wired on an ignition live and powers up fine.
The trouble is it can only get 1 bar of signal on about half of the channels. I did manage to hear someone on one channel but it was fairly distorted and so far I haven't reached anyone either.
I'm wondering if it's an earthing problem, is my cable too long or is there just nobody in my area?
Thanks for any help
Nube set up question
- wildfire
- CB Handle: wildfire.
Hi Toddle,
i have checked what equipment you have bought & it looks like you have a small orbitor antenna for better performance i would recommend a larger antenna as small base loaded antennas only do a distance up to 5 to 10 miles while larger antennas can do a distance up to 20 to 30 miles
