hi i have just installed a cb in landrover with antenna on gutter mount and when i press mic reading is swr maximum , i have also conected wire from antenna to battery neg to ground it ,i this ok
i am very confused what to do next and am thinking of buying swr meter ?
please help lol
you need to SWR always, get one asap, but that doesn't sound like your problem
the aerial needs to make good contact with a "ground plane", think of it as a metal mirror to reflect the waves up & outwards - aluminium body work doesn't do this
the aerial negative/coax shield needs to be "earthed" to negative, which the neg power lead to the radio should achieve, but another wire to a good earth will help.
make sure your extra neg wire is not touching the aerial or centre wire, but just the outer sheath
