Clouddancer/ Newbie
Clouddancer
COAX Cable
What is the best Coax Cable for Mag Mounts apart from RG58.
I understand there is better shielded Cable. than above.
Enterprise
RG58 Mil is good. RG213 is better but is so thick it would make the mag mount unwieldy and the performance increase would be neglible.
AppleTree
CB Handle: Uncle Bulgaria
Just use RG58, I do.
You Can Find Me On Channel 19 Usually.
Or 145.500 FM 8-)
My YouTube Channel RustySkull Productions
Clouddancer
Many thanks for the replies re :- RG58 Coax.
Reason for query :- I was informed that the RG58 was just about passible for use. :!:
there are thousands of cber's useing it around the world so must work ok
