Hi all,
I recently bought a pair of little Wallis talkies for a trip to wales which made me think that getting a cb would be a good hobby , so before I buy my equipment I first thought I’d see if there are any aerial installers that do cb aerials but unfortunately no company I’ve phoned will do it, does anyone know anyone that can install a cb aerial in the Birmingham area and perhaps get me set up.
Many thanks Lee
Newbie
Enterprise
I've got the same problem in Telford, need to get my homebase aerials up.
I think most CB'ers are likely to be of a mind to do it themselves, hence the lack of professional installers. With that in mind, I'd probably suggest doing some research on installing and tuning antennae & then getting up the ladder (or if you're not able/willing to faff with that, start off mobile with a mag-mount in your car & when you've made a few contacts you might find someone local who'd be up for helping out with your home base antenna.
Good to see there's still a few of us out there interested in getting on air legally licence-free, likewise good to see a few still hanging around on forums rather than wastebook (I hate antisocial media with a passion, and refuse to carry a mobile phone also haha)
You don't need to spend much either really, if you look over your local auctions and the like you can get set up a lot cheaper than buying spanking new kit. I'm on 40FM for the princely sum of £12 for a pair of radios/mics and SWR meter plus £19 for a mag-mount antenna so up & running for under £35.
- wildfire
- CB Handle: wildfire.
we can explain how you can set your own cb set up by yourself but it all depends on your location & what your looking for if it's for mobile use & your just looking for something basic then here is a tip matey
https://www.thunderpole.co.uk/swr-meters/swr-1.html
https://www.thunderpole.co.uk/magnetic- ... large.html
https://www.thunderpole.co.uk/large-cb- ... bitor.html
if your looking for a homebase & your in a valley then from the top of my head I would seriously suggest a 1/4 wave antenna otherwise your signal will struggle with buildings & hills around you but if your on flat ground I would look out for a 5/8 wave as 5/8 wave antennas work better than a 1/4 wave but also a 1/4 wave antenna will work better if you have obstacles around you buildings, hills ect
the Boomerangs do work well for the size of them& you also have a choice of a 1/4 wave or a 5/ 8 wave & shouldn't course a lot of faffing about with lol
if you do decide to go for one of the Boomerangs you'll need a pole & I would suggest this pole at the following link
https://www.thunderpole.co.uk/homebase- ... t-kit.html
& you'll also will need coax & of course a swr meter if you haven't got one buddy & good luck with what ever you decide
