but if you put your hand on the Arial it stops and when you let go it starts again??..
needle pulses
- andy@thunderpole.co.uk
- Site Admin
Sounds like interference coming from somewhere...
Is it in a vehicle? Do you have your engine running?
- Site Admin
Still sounds like interference, not from the alternator but coming from somewhere. Could be other electronics in the car that arent killed by ignition switch.
Or maybe coming from somewhere else? Have you tested with car parked in different places?
tranexneil
Check the battery, ie: connect the radio to a different car battery in the same vehicle if that solves it you have a High Resistance battery ! Ive seen similar issues on PMR equipment, Can also be caused by a corroded fuse / Holder.
Regards
Neil
Regards
Neil
Well I have been told that the needle pulse is due to my clock and the rig being in the glove box next to the fuses
so I am going to move everything today and also swr up the Arial with my new meter that I have just purchased from the flee-bay.
ok
I now have moved the rig to the rear shelf and no pulse perfect.
Attached the swr meter and low and behold swr way out sitting at 5.5 ..
Can get it down to 3.5 to 4.0 but can’t get it any lower...
You know what I am going to ask don’t you...
How the hell do I get it lower …
