Massey 6270
cblundon
CB Handle: Pike
Hi all,
I work on a small dairy farm so there isn't much road haulage as such, however when on silage or maize could do with cb.
I recently purchased a tti tcb-550 second and a cheap cb aerial magmount.
my query being what bracket should i use for the tractor as i need to be able to remove and install it easily and quickly as it couldn't stay in the tractor.
Over
Pike
Goose Berry
Hi Pike, :)
depending on what range you want for the cb, a small ariel (20cm to 66cm) would be handy in your situation but it would be a range of about 5 miles at best (in normal conditions), where as if you want max range your looking at an ariel 1.5m to nearly 3m tall on your magmount. :)
10-10 :)
Hi Pike
I take it your looking for a bracket for your radio I'm surprised one didn't cone with it but depends on the site of your radio but here are a couple for the TTI radio's matey 😉
https://www.thunderpole.co.uk/cb-bracke ... 172mm.html
https://www.thunderpole.co.uk/cb-bracke ... 141mm.html
