CB BURNERS
Tigger
I bought a burner of a guy on eBay , the burner is 100watt am 200 watt ssb , I am at the moment using a president Richard on the UK FM 27-81 UK .
Now the guy selling the burner tells me that yes this will wo rk fine on FM UK just set it on am , so I bought it from him and once it arrives I try this burner out ,
Well it seems to transmit ok as people are saying they can here me but when the burn is on I cant here them unless I turn it of after transmitting
Does anyone know of this fault before or is it just not compatible with the FM UK only as it say just for. Am and ssb . Any thoughts people would be greatfully received.
Radio Lilac
Tigger! I suspect your burner probably works. However the increased power means that you can be heard by stations that may not have burners. This means that you won't be able to hear them if you are out of range. Radio Lilac. :D
