silver rod
skyrider
right i have just bought a venom high gain silver rod 1/2 wave and and i fixed the jubilee clips to all the black marks on all sections , i also fixed an earth wire to the ant and to a steel post in the ground , the antenna is fixed in a tree in the garden and even though i lower the bottom section im still getting a high swr any ideas thanks :-k
skyrider
is there a minimum length for a pole on an antenna :?:
If it is mounted in a tree, are the branches neat to the antenna?
The entire antenna needs to be above the any obstacles, otherwise the SWR will be high.
Andy.
skyrider
Hi Andy i call it a tree but really it is a big holly bush and this time of the year not many leaves and very few branches but i think i have found the problem the rg58 coax i was using one of the pl259's was not screwing into the ant the threads were bad so i have been in touch with the supplier and they are going to send new coax with pl's plus most of the ant is above the bush anyway thanks
Good stuff, hopefully that will solve the problem :)
skyrider
how many sections should there be on the silver rod 1/2 wave not including the one with the fixing plate :?: thanks :)
There should be 4 telescopic sections that go inside the bottom section.
Andy :)
skyrider
great that's what i have thanks Andy :D
