New Rig
stu
Hi Guys,
I got the Intek M-490 CB Radio and the Antron-99 Aerial.
I got it all set up last night, but i'm getting a reading of 2.75 SWR.
I know this isnt right.
I have the arial attached to a downpipe (CastIron although it is laquered with paint from all the years) via jubilee clips and A+ Tie raps, and the aerial has been separated from the cast iron aswell with polythene wraps.
What could I be doing wrong?
Any help appreciated.
Stu :)
check swr on it you can not mount antenna directly on to a drain pipe as in picks up reflection and gives you a high swr strap a 6 ft pole to drain pipethen mount antenna to top of this pole thus lifting the base on the antenna above the guttering and drainpipe you will find better performance results do not worry too mutch about the output power as you can realy only get a true reading on the work bench
cheers and beers
b
stu
Hi PPL,
Just a quick one to let you all know, I got the SWR right down to 1:1.1 yesterday with my A-99.
Hoisted the aerial above my roof using the existing SKY bracket that was there with the clips included in the pack.
Stu 8)
Basilsparents
Wonderful SWR... *jealousy*
Round Baler
How far were you hitting and how many pounder?
- Gordon
Round Baler
trik
Good swr doesn't always mean a good signal,afterall,if you transmit into a dummy load you will get a good swr,but your range will be erm...restricted!! :-({|= :cry: :-#
regards
trik
