needle pulses
yes aye ok right smack on hit the nail on the head bang on ok doky your right
stevie_a
thanks you are some man :wink:
we try our best when we have lucid moments thanks
:D :D :D :D :D :D :D :D
stevie_a
HELP !!!
Ok I have been out to the car tonight
Swr at 4 /4.5
Cut a wee but about 4 / 5 mm swr the same
Cut another bit off 4 / 5 mm swr jumped up to 8
Moved the rods about got swr down to 5 / 5.5
What am I doing wrong?
sounds like a bad earth or a baseloaded antenna thats geting reflection from the car try a top or center loaded antenna photo might help
stevie_a
I take it you want to see my antenna
gaspipe58
:shock: :oops:
fatfinger
Official CB Legend!!!
put that mag mount in the bin you will never get the swr down there crap
i had 1 after lots of cuting got it down to 3
did you get it of ebay like i did
learn the hard way and spend the most money on the mast, thats the bit that matters the most
stevie_a
fatfinger wrote: did you get it of ebay like i did
YES I DID... :oops:
I don't want anything big.. :wink:
fatfinger
thats not what i have been told :lol:
nice rotel 220
i have 1 of them
get a little willy from colin they are small and will swr easy job solved
stevie_a
I take it you are talking about a Wilson Littlt Wil at £29.99 what size is the Diameter of the base i can see the hight is .95mm
about 3" estimate colin will measure the diameter for you if you ring him
boyscout
Yes Steve you do. I would say that when I cut down my antenna I do only cut off about 3mm at a time, yes it can be a pain and takes longer, but I think it pays off in the end. As said before, if you rush and cut to much off then you have gone past the point off no return. One other thing is next time you are trying to find out where the interference is coming from remember it can enter in two ways, through the antenna or through the power line. I think I'm right in saying if you fit a dummy load to the rig and the interference is still being heard, then the interference is coming in through the power line. I would add a ferrite ring to the power lead. Hope my 2 bit helps :?
boyscout
fatfinger wrote:put that mag mount in the bin you will never get the swr down there crap
Funny thing that, I have a Siro ML-145 on a mag mount and the SWR on Ch 40 is 1.3 and Ch 1 is just below 1.2
I don't think that you can right one thing off and say it's bad as there are so many variables to take into account. i.e. Make and type off antenna, good grounding and where antenna is situated, just to name a few
One thing I have learned is that it's mostly down to trial and error. and as you said spend the cash on a good antenna, you may have the best rig in the world, but if your sporting a cheap naff antenna there is not much going to go off at the business end. :|
