needle pulses
put that mag mount in the bin you will never get the swr down there crap
i had 1 after lots of cuting got it down to 3
did you get it of ebay like i did
learn the hard way and spend the most money on the mast, thats the bit that matters the most
thats not what i have been told
nice rotel 220
i have 1 of them
nice rotel 220
i have 1 of them
Yes Steve you do. I would say that when I cut down my antenna I do only cut off about 3mm at a time, yes it can be a pain and takes longer, but I think it pays off in the end. As said before, if you rush and cut to much off then you have gone past the point off no return. One other thing is next time you are trying to find out where the interference is coming from remember it can enter in two ways, through the antenna or through the power line. I think I'm right in saying if you fit a dummy load to the rig and the interference is still being heard, then the interference is coming in through the power line. I would add a ferrite ring to the power lead. Hope my 2 bit helps
Funny thing that, I have a Siro ML-145 on a mag mount and the SWR on Ch 40 is 1.3 and Ch 1 is just below 1.2fatfinger wrote:put that mag mount in the bin you will never get the swr down there crap
I don't think that you can right one thing off and say it's bad as there are so many variables to take into account. i.e. Make and type off antenna, good grounding and where antenna is situated, just to name a few
One thing I have learned is that it's mostly down to trial and error. and as you said spend the cash on a good antenna, you may have the best rig in the world, but if your sporting a cheap naff antenna there is not much going to go off at the business end.
