Hi Signal reading
i'm going to use the battery from my caravan
and put it in the house when the wife is out
seems to be worse near my b band router
first thing i did try
did not work
going to kill all power next and see if it is me
did not work
yes still the same mate
One thing you could try and it says to do this in one of my computer books is find an old AM radio (not CB just a plain old radio) and off tune in from a channel, turn it on and walk around the equipment you are testing. You should hear the RFI through the speaker when you get near the offending bit of kit.
Noooooooooo that would be like cutting my right arm offstampman wrote:try cutting the power to the router first then and see what happens
But could be the main cause of RFI with the amount of computers and geeky stuff running in my house.
I think my son would take a fit if I turned the router off every time I used the CB.
One thing to note is that WiFi runs on 2.4Ghz and that is no where near the 27Mhz band. So could this still cause RFI????
I must say that most of the IT equioment now days does come fitted with ferrit rings install on the equipment. So that would just leave the fans inside the computer!
May just add a ferrit to the IEC power cable to the PSU, see how that goes
to be continued.
nooooo if the interferance is still there with the comp switched off then putting rings on the power lead will do nothing but cost you to sort rf out you have to find the source first then use the bell book and candle to exorcise it
stampman wrote:whats life without problems
